Poor covering power in zinc plating process
Thickness ratio high current density -to- low current density is low value. because of this our materials scale after zinc plating
Duygu Akbay- Turkey
April 26, 2008
April 28, 2008
Hi, Duygu. You need to give us something to work with. Barrel or rack plating, acid or alkali, do you use auxiliary anodes, is the thin area within a hole? Let us at least picture the problem and then we may be able to suggest whether coverage is possible or if you need to look at another way of avoiding rust.
