Phosphating: Can't dissolve zinc oxide in phosphoric acid
Zinc Oxide Powder
zinc_powder
Q. To whom it may concern, hello,
I am looking for a high quality zinc phosphate solution that has uniform coverage and good corrosion resistance and is also suitable for painting.
When I want to dissolve zinc oxide in phosphoric acid, if the amount of zinc oxide exceeds a certain limit, it is not dissolved in phosphoric acid and zinc oxide particles are scattered and precipitated in the form of white grains in the solution, and this makes the solution I don't have proper phosphate.
Ingredients I use for zinc phosphate in 100 ml volume:
Zinc Oxide 1/8 g
Phosphoric acid 4/5 g
Sodium nitrate 0/5 g
Any information on this topic will be greatly appreciated.
Amin Babak
- Mashhad, Iran
April 28, 2024
SUGGESTED PHOSPHATING BOOKS
(many of these are rare; the links will only sometimes work)
phos_sharma22
"Optimization of Phosphating Process" by Vinod Prasad Sharma (2022)
phos_rausch1991
"Phosphating of Metals" by Werner Rausch (1991)
phos_freeman1991
"Phosphating & Metal Pretreatment" by D.B. Freeman (1986)
phos_lorin1974
"Phosphating of Metals" by Guy Lorin (1974)
biestek
"Electrolytic and Chemical Conversion Coatings" by Biestek & Weber (1972)
"A Study of Manganese Phosphating Reactions" by Joseph Menke (1971)
phos_spring1966_rare
"Preparation of Metals for Painting" by Samuel Spring (1966)
"Continuous Automated Analysis and Control of phosphatizing Baths" by Edward P. Parry (1972)
Q. Hello
I want to make zinc phosphate (coarse grain). but I have a problem with dissolving of ZnO in phosphoric acid. How can I solve it ? Which formula do you introduce me to?
best.
Mansour Kashiha
coating shop - Tehran, Iran
April 25, 2008
A. If you want to make zinc phosphate solution for phosphating you can use zinc phosphate not zinc oxide and the chemical contents as following:
ammonium fluoride this on eBay or Amazon [affil links] 10 g/l
zinc phosphate this on eBay ] 17 g/l
phosphoric acid this on eBay or Amazon [affil links] 300 g/l
nickel nitrate 20 g/l
ammonia this on eBay or Amazon [affil links] 8 g/l
With best regards,
Ali Gomaa
- Cairo, Egypt
