Pt16 surface finish parameter conversion
Is there a way to convert a Pt16 surface finish parameter to either an Rz, Ra, or Rq surface finish parameter?
Jason Swenson
Director of Quality - New Troy, MI, US
April 22, 2008
Have you or can you reverse engineer this problem by measuring the surface with a profilometer? Another option is to find out the environment it is to be used in. Last or first, ask the potential customer or engineer.
tony kenton
AF Kenton
May 1, 2008
