Teflon Coated Blots versus Lubricant
April 18, 2008
I have been asked to research the effects of using teflon coated bolts versus lubricant by means of using them for flange installation on steel pipe ranging from 3" to 36" diameter.
Does anyone have an idea as to the friction factors between the two? Or proportional torque required?
Product Designer - Santa Clarita, California, USA
Have you considered moly di sulfide, known as dry film lube. It can be cheaper than teflon, more available and quite good.
James Watts- Navarre, Florida
April 21, 2008
