Stainless steel grading device
Is there a hand held tool or device that can tell you what grade of stainless that is being tested? Specifically we would like to be able to test the grade of stainless being supplied on our equipment.
Joe Dupreeindustrial service tech - Houston, Texas, USA
April 15, 2008
Hi, Joe. Please search the site with terms like "scrap sorter",
"spot test", "spark test" because there are dozens of threads on the subject -- it's all a matter of how much you are willing to spend. For $35,000 or so you can have a hand-held scrap sorter
⇦ this on
Amazon [affil links] X-ray fluorescence machine.
April , 2008
The easiest way to tell 200,300 from 400 series is with a magnet. If the magnet stick to the stainless, then it's 400 series, otherwise it's either 200 or 300 series.
Another option, is perhaps send it to lab for testing.
$35K is a lot of money if you don't need to test it frequently.
Michael Liu Taylor
specialty stainless steel distributor - Dallas, Texas
April 24, 2008
Hello,
TWO METHODS:
1) Elemental analysis cost around 400 dollars *The best one).
2) Microstructure analysis costs around 80 dollars
- Minneapolis, MN, USA
June 11, 2008
