Electricity from water
I am preparing a tenth class project.How can I produce electricity out of salts present in sea water?
Twinkle G
- Delhi, India
April 4, 2008
Hi, Twinkle. Your question may make sense to you but I don't understand it. Please tell us your project assignment, or give us an abstract of the project you have undertaken. Thanks.
April , 2008
April 10, 2008
Hi Ted, Does the project state by any means - if I am correct (and my school days are long past) I suggest the following:
If you place two different metals in a salt solution and connect them together with copper wire via a voltmeter you should observe a slight flow of DC current. You have just created a galvanic cell, sometimes the process is loosely referred to as electrolysis. This is due to the fact that one of the metals becomes the anode and the other the cathode and as an example a steel bar connected via a voltmeter to a magnesium bar you may obtain a flow of 2.5 volts DC current.
I stand to be corrected by a physics prof.
Terry Hickling
Birmingham, United Kingdom
