Selling Excess Chemicals?
Does anyone know of a company that will buy unused chemicals? I work at a plant that has some excess compressors oils, antifreeze, rust preventatives, gear oils....etc. Most everything is in 55 gallon drums.
Brian ScottChemical Manager - Marysville, Ohio, United States
April 1, 2008
Hi, Brian. You can look up "industrial waste exchange", but those outfits are probably more likely to take the chemicals off your hands for nothing rather than buy them.
April 2, 2008
Unless you found it already, try chemdeals.com
Alexander Boltenko- Vicksburg Michigan USA
December 10, 2008
