Skipping Phosphatizing Process for Aluminum Painting
Hi there
I would like to know, what if I skip the phosphatizing process to aluminum frames from my paint line.
I paint both steel and aluminum frames but I'm not sure if phosphatizing just applies to steel and not to aluminum?
Thanks and best regards.
Plating Shop Quality Engineer - Quer´taro, Mexico
March 26, 2008
Aluminum, like other metals, must be pre-treated before painting, Miquel. The best pretreatment is chromate conversion coating. Next best is phosphatizing in a phosphating bath which is designed to handle aluminum as well as steel. Not pretreating is not a good option. Good luck.
March 27, 2008
Fluorides added to the phosphate etch the aluminum in a multi-metal phosphate bath, so you are right in that the phosphates aren't the pretreatment for aluminum. It would probably be a good idea to talk to your chemical vendor and find out exactly what he is selling you. ![]() Sheldon Taylor supply chain electronics Wake Forest, North Carolina March 30, 2008 According to some expired patents(try uspto.gov website) tannin based solutions(1 gm tannin/0,003 gm titanium potassium fluoride/1 lit water) can be used as pretreatment too.Maybe not so effective as hex chromates or phosphates but much more environment friendly option.Hope it helps and good luck! Goran Budija- Cerovski vrh Croatia March 31, 2008 |
