Buffed brass has silver colored areas
March 25, 2008
I have 6 or 7 brass lamps that I had in Florida ( salt in the air )and were not well cared for. They look very tired. I have started with one to see if I could "do it myself". I adapted my grinder for buffing. I stripped whatever lacquer or shellac there was. I've cut and color buffed the parts finishing with a red jeweler's rouge ⇦ this on eBay or Amazon [affil links] , then washed in soapy warm water and dried with soft cloth but I find areas that appear silver in color. A magnet is not attracted to the brass so it's solid. Have I buffed too aggressively, not enough? Wrong compounds? Do you have any ideas what is causing the silver colored areas?
Ben Broderickhobbyist - Castleton on the Hudson, NY USA
I would not be so sure that they are brass, Ben. They may be aluminum or die cast zinc. So it's possible that the brass plating is worn off. The best answer would be to send them to a plating shop for replating, but it's possible that a wax based rub like
Rub n Buff
⇦ this on
may be good enough. Good luck.
March 27, 2008
