Coloring galvanized water taps
I wish to color the nickel galvanized copper water taps made in our country. I want some light shiny colors apart from the traditional nickel plated taps. Can anyone suggest some process or chemicals that can be used in the galvanizing process to derive those colors?
Your help will be highly appreciated.
want to start a coloring business - Bangladesh
March 27, 2008
Hi, Khaled. You cannot do this within the nickel plating process, but you can do a secondary process of applying translucent electrophoretic lacquer to the taps.
March 27, 2008
Try uspto.gov website-there you can find at least 2 patents on that subject(download free).Hope it helps and good luck!
March 31, 2008
