Rinsing time before electroplating
u.s chrome
March 24, 2008
Dear Sir
We do ID hard chrome electroplating on cylinder sleeves. Before the process we do alba washing and then soft water rinsing & Etching.
How much time should be given to workpieces before the electroplating or after rinsing so that no rust appear on it?
Mohsin Siddiqui
- Karachi, Pakistan
There should be no delay at all between any steps, Mohsin. The parts should be rinsed for the minimum time which allows good rinsing (probably something like 30 seconds, depending on the part and the amount of agitation available), and allowed to drain for the minimum time that does not cause excessive dragout and pollution. In no case should they be allowed to dry. Good luck. P.S.: I don't know the meaning of "alba". Thanks.
March 25, 2008
Dear Sir Ted
Alba-788 is a chemical that we are using for cleaning the workpiece (any impurity, oil etc) than workpiece go to rinsing tank and than to etching followed by hard chrome electroplating.
what is the probability of getting rust after rinsing, when we left the part for 10 mins after rinsing / before etching it gets rust so quickly, what could be the reasons for getting rust on workpiece?
please help
Mohsin Siddiqui
- Karachi, Pakistan
March 25, 2008
The answer is: don't do that, Mohsin. It is improper processing to take a part out of the line after cleaning. Clean parts are susceptible to flash rusting; it is no surprise that they rust in 10 minutes.
March 26, 2008
Dear Sir Ted
Thank you for your answer, I was really worried about the case that why do the parts get rusted so quickly after cleaning.
Mohsin Siddiqui
- Karachi, Pakistan
April 8, 2008
June 5, 2008
hello Mr. MOHSIN,
YOU FIRST MAKE READY YOUR HARD CHROME PLATING TANK,
THEN START FROM CLEANING PROCESS,ETCHING,RINSING,AND HARD CHROME .
NO STAY BETWEEN ANY STEP.
ENJOY PLATING,
BYE,
AFTAB
KARACHI
Aftab Jahangir
Aftab Jahangir
chemist - Karachi, Pakistan
They flash rust because they are clean, chemically active,wet and exposed to oxygen.
u.s chrome
