Passivate stainless medical instruments before or after TiN coatings?
March 4, 2008
Should we passivate before or after TiN coating on 17-4 ph stainless steel.
I believe we should passivate before but I'm not totally sure.
Thanks for your help.
Scott Jones
- Mcmurray, Pennsylvania, USA
Passivation should be before, since TiN is very corrosion resistant by itself. It is quite thin, so it does not have an infinite corrosion resistance life.
www.finishing.com is made possible by supporting advertisers ...
