Yellow vs. Black Chromate
I simply need to know which will last longer in a continuous salt spray test, a steel part coated with zinc/yellow chromate conversion, or one coated zinc/black chromate conversion, or does it make any difference?
Aaron Acton- Westfield, Indiana, USA
Hi Aaron,
From my understanding, black zinc chromating can last longer in salt spray test. Regards.
Kwok-wai ChookHong Kong, China
Should it be the other way around that a yellow/iridescent chromate conversion coating last much longer than a black chromate on electrodeposited zinc at a standard 5% salt spray test?
S. Y. Yuen- Hong Kong, China
The yellow lasts longer - 96 hours in 5% ss. But if you are really looking for a long time in SS, try a zinc alloy like zinc iron with black chromate (no silver needed) ,zinc cobalt or zinc nickel.
Sara Michaeli
Tel-Aviv-Yafo, Israel
I have done many salt spray tests on both. My vote is for yellow!
Tim Neveau
Rochester Hills, Michigan
