Electrically conductive aluminium enclosure
I am designing an aluminium enclosure assembling with several pieces throgh fastener. The ousides should be black anodized and internal surfaces should be conductive and there is no corrosion issue after long run.
What is the best solution ?
Harris Wang
Product designer - Mississauga, ON, Canada
February 20, 2008
Hello Harris. This is not unusual. The plating shop can anodize the outside and either chromate conversion coat or electroless nickel plate the inside.
February 21, 2008
I use either a Chem Film, Iridite, or Alodine finish for the conductive surfaces. Ask them to Chem Film the part per MIL-C-5541E, then mask the area you want to be conductive, then anodize.
Paul Costales
research - Santa Barbara, California, USA
March 11, 2008
