Dull plating on ABS
We do Cu-Ni-Cr plating on ABS plastic but recently facing a dullness (mostly at LCD) on finished goods. We tried out with increasing & decreasing current densities but no result, we also done the excess addition of brighteners but the issue is same. So suggest the solution.
Manish Rastogi
Plating Engineer - Gurgaon, Haryana, India
February 17, 2008
Hello, Manish. Have you run Hull cell panels and, if so, what results are you getting? Please don't tell us you add and remove brighteners from a production tank without trying things in a 267 ml sample first :-)
February 19, 2008
