Determination of 70% HF strength determination
Am working in the Mining Industry and am using 70% HF for ore treatment. I need a reliable method (wet or instrumental) that I can I can use to gauge the strength after a number of treated batches.
Modise Molale
LAB EMPLOYEE - Gaborone, Botswana
February 19, 2008
In Situ Method:
Mount and polish a sample and evaluate it in the microscope. Then you will be able to know the capacity (power) of your solution.
If you want to refresh your solution, then use titrations.
Jose Castellanos
Minneapolis, MN, USA
Jose Castellanos
- Minneapolis, MN, USA
February 27, 2008
February 27, 2008
Working with 70% hf is extremely dangerous, including the white cloud of fumes that comes off of it.
One way to check it is to do a titration with a ion specific electrode and appropriate standards and quench solutions.
If there are no other acids, you can do a simple acid base titration with 1N or 0.5N sodium hydroxide this on eBay or Amazon [affil links] to a methyl orange this on eBay or Amazon [affil links] or similar pH color indicator.
