How to etch galvanized iron sheets
Am into hobby handicrafts, we have just bought spray etching to make lamps, I want to cut galvanised iron sheets thickness .5mm, I have tried with nitric acid, the problem is the glue comes off while cutting,
and when we have to take off the photo sensitive glue, this glue also come off when we do stripping using NaOH
please help
Alex adson
hobbyist - Alaska
February 17, 2008
Please try to etch galvanised sheet with diluted Phosphoric Acid (10-50 grams per liter)
yehuda blau
Yehuda Blau
YB Plating Engineering and Quality - Haifa Israel
February 20, 2008
