Mini Anodizing Line
My little 1st grade girl is interested in how to color coat aluminum. I recently started working at a anodizing place. I heard from someone down the line that you can set up a little line using 9 volt batteries, is this true, how and what would I need for this.
Thanks for any input.
Guy Brooks
- Oregon
February 14, 2008
February , 2008
Check the voltage meter on the anodizing rectifiers in your shop in the middle or near the end of a cycle. I think you'll need at least 12 volts, not 9.
Battery Charger
battery_charger
12 volts is not very good. You need 14 to 18 volts. Look for a small battery charger this on eBay or Amazon [affil links] for "marine" batteries. They put out about 14.6 volts vs 13+ for a car battery charger. Go online and look for a cheapie.
