Thread 478/27
Mystery Electrical Problem in Watts Nickel Bath
February 13, 2008
We barrel plate a lot of parts in a Watts type nickel bath. This problem started appearing about a month ago. The current level on my rectifier drops to less than 1/2 the normal level and fluctuates wildly. The parts stop plating and the danglers become dull and sometimes have nickel crystals on them. I think they are nickel sulphate crystals. I check all my electrical connections and they seem fine. For the heck of it I hooked up one lonely penny to the ground wire and plated it for a few seconds and then hooked up the barrel again and all was well. I have done this now three or four times and it seemed to solve the problem. Now it is not working anymore.
Right now I am dummy plating it to see if it works.
Is this polarized anodes? I ran 4 barrel loads through it today before this started happening again.
Plating Shop - Cleveland, Ohio
publicly reply to Terry Collins
It is indeed a mystery, Terry. Personally, I don't think it involves passive anodes. That would prevent the anodes from dissolving properly but would not block current flow; plus the nickel concentration should drop, rather than grow, so crytallization would seem especially unlikely.
I don't like your use of the phrase 'ground wire'; neither pole of the system should be grounded.
My first guess is that it's simply your rectifier acting up. Try a substitute rectifier.
February 13, 2008
publicly reply to Ted Mooney
It sounds to me like you have a power problem, not an anode one. I would suggest you recheck all your electrical wiring and connections- even better, replace them all. Also check your rectifier is working as it is supposed to. I would also clean all the connections and bussbar contacts.
publicly reply to Trevor Crichton
Dear Sir, the fist question is: when did you do the bath analysis recently. Please inform about the result. In my opinion you have very low chlorides ions in the bath. Very low boric acid is also possible.
Janusz LABEDZ- Warsaw, Poland
February 19, 2008
publicly reply to Janusz LABEDZ
Hi,
Check the recitifier because I think you have AC in the recitifier.
Anders Sundman
Anders Sundman
Consultant - Arvika,
Sweden
February 19, 2008
publicly reply to Anders Sundman
Anders! Long time no hear. Welcome back.
February 19, 2008
Thanks for your replies. I have done an analysis on the bath and all the parameters are within normal.
I used the term ground wire in reference to the negative connection to the rectifier.
I agree that this must be an electrical problem. Since it only happens when I use the barrel I think I need to make certain I am not getting AC or a short through the barrel.
When I figure this out I will post the solution here.
- Cleveland, Ohio
February 24, 2008
In your first posting, you said you would do a dummy plating, how is it?
It seems to me that loose contact(it happen on certain barrel?) plus passivated anode caused your problem because with the same rectifier sometime it worked.
publicly reply to John Hu
Hello,
If you have check all electricity and you rectifier please chek also the wetting agent in your nickel solution.
Anders Sundman
Sweden
February 27, 2008
Hi Terry,
Just a few questions. Is your rectifier constant current or constant voltage? You said the current is fluctuating.
How about the voltage, is it fluctuating as well? Do you have another rectifier so you that you can be sure whether it is your rectifier or not?
You also said the bath analysis was ok. What are you using to corrode the anode, Chloride or Bromide? How long have you been using the anode?
Good luck in your troubleshooting. It definitely looks like an electrcal problem.
Maurice.
Electroplating - Danbury, Connecticut, USA
February 29, 2008
publicly reply to Maurice Mason
I agree with Anders as it is an AC impedence problem in the rectifier. I encountered an instance in which one of three fuses were blown in a standard tap switch rectifier. You may want to check.
Best of luck!
Kansas City, Missouri
March 1, 2008
publicly reply to Ira Donovan, M.S.F.
Mr. Terry,
Please take hullcell and find out whether solution problem or current problem. Hull cell wil give clear indication.
P. Gurumoorthi
electroplating process chemicals - Chennai, Tamilnadu, India
March 5, 2008
publicly reply to P. Gurumoorthi
