Descaling of lead weights for reuse
Dear Sir
Kindly suggest me a solution which will dissolve or brighten the surface of lead.This is to use the lead weights which are already used.The solution must be risk free use.
Thanking you
with regards
C.K.Raveendhran
Metal Printing and Surface Finishing Industry. - Coimbatore, Tamil Nadu, India
February 13, 2008
You seek a material that is capable of dissolving lead but is risk-free to use? Nothing is risk-free, let alone a chemical strong enough to react with lead. Good luck :-)
February 13, 2008
