  Thread 477/60
A356 Tapped Hole "Blowout" During Type II Anodizing
February 6, 2008
47760 anodizing blow-out
John Kuenzly
Mechanical Engineer - Ojai, California, USA
publicly reply to John Kuenzly
simultaneous replies February 8, 2008
Stainless Steel Heli-coils
helicoils
A. Didn't the plater tell you "do not anodize aluminum with heli-coils inserted, or who did not listen.
A blow out would not be expected, but severe erosion of the hole would be expected along with the heli-coil being worthless if it was still there.
Bad plan!
publicly reply to James Watts
A. John
The heli-coils should be installed after anodizing. Masking helicoils is challenging, to say the least.
If the part was anodized with the helicoils installed and not masked, I would expect to see most if not all of the helicoil dissolved, and if the process was hard anodize, I would expect to see a significant amount of aluminum burned away- no visible threads, the hole larger near the surface, and little or no anodize present in the surrounding areas. A catastrophic failure.
Willie Alexander
- Colorado Springs CO
February 8, 2008
publicly reply to Willie Alexander
A. Most definitely this would be the cause of your problem. Only aluminum should be anodized. Steel dowel pins, or helicoils are incompatible with the anodizing process, and won't survive the anodizing process unless they are adequately masked (which can be tricky). Ideally you'll want to install any hardware, that is not aluminum, after the anodizing process.
Marc Green
Marc Green
anodizer - Boise, Idaho
February 8, 2008
publicly reply to Marc Green
A. Whoa! You cannot anodize aluminum that has any other metal attached. Immediately after the aluminum becomes slightly anodized, and therefore slightly non-conductive on the surface, the current goes to the easiest place which is the stainless steel and starts "un-plating it" until it is completely dissolved and all gone.
robert probert
probertbanner
February 9, 2008
publicly reply to Robert H Probert
Q. I'm designing an aluminum part that needs to be teflon anodized, and also has several holes that need to maintain a very tight tolerance for a precise press fit. Based on the tolerances of the pins used for the press fit and the machining tolerances of the aluminum part, the added thickness of the anodizing layer would have to be held to ± .001mm (approximately ± .00004 in).
If the stainless steel pins are pressed into place before anodizing, will the anodizing process have any effect on the pins or will they simply act as plugs?
Jayson Moore
design engineer - Cincinnati, Ohio, USA
July 20, 2011
publicly reply to Jayson Moore
A. Hi, Jayson.
As you see, we appended your inquiry to a thread that answers it. You can't do that. Robert Probert's reply is the most applicable to your situation.
June 2011
publicly reply to Ted Mooney
