"Kindorf" bolts
I work for a company and I'm trying to order parts that are called (Kindorf) the bolt is yellow in color and is a grade 5 ,What is the proper name for it ?
Troy Scott
shop employee - Baltimore, Maryland
February 1, 2008
Kindorf is not a finish it is a brand name of a "patent channel" system, similar in concept to Unistrut. The channel system including hardware is available in many finishes. If the bolts are yellow they are probably zinc plated and chromate conversion coated, but that is just a guess.
February 1, 2008
