Electrically isolating, thermally conductive coating for SST
I am looking to coat stainless steel with an electrically isolating, but thermally conductive coating. It has to stand up to about 500C operating temp & be somewhat "tough". Any suggestions?
Steve Ayresproduct designer - Northville, Michigan
January 31, 2008
First of two simultaneous responses -- February 2, 2008
Hello Steve,
Although it seems to be joking the best heat conductor among electric isolators (dielectrics) is diamond. Really. But seriously, PTFE is quite good heat conductor, but very good eletric isolator.
Best regards
Aurotech - Warsaw, Poland
Its just a matter of how thermally conductive and how electrically insulating you want it to be. If I remember well based on physics, most anything that is a good thermal conductor is also a good electrical conductor. All plastics are out, obviously. Ceramics are also out. Maybe only some intermetallic compounds but they will be very thin, like Titanium nitride or similar.
February 2, 2008
It should be coating of less or equal to 2-5 micron thickness made from dialectic such as Al2O3, MgO, CaO or similar. The specific conductivity is very low, and thermo conductivity will good enough for such thin layers.
Anna Berkovich
Russamer Lab
Pittsburgh, Pennsylvania
February 7, 2008
February 21, 2008
Depending on financial aspects diamond is really an alternativ to think about! It can be plated as DLC (diamond like carbon) via PVD.
Greets from Munich
Franz
Automobile production - Munich, Bavaria, Germany
