Any concern about electroless nickel plating in water service?
Is there a problem with contamination to water from a electroless nickel plated fitting?That is, Any traces of the plating transferring to water?
Tim Skeens
Designer - Cleveland, Ohio
January 15, 2008
The corrosion rate of electroless in drinking water is nil according to many authors and most respected publications.
Guillermo Marrufo
Monterrey, NL, Mexico
January 19, 2008
