citric acid as an additive for iron contamination in watts type bath
I have a bath that seems to have a serious iron contamination, because the anode bags are brown I found that the citric acid ⇦ this on eBay or Amazon [affil links] could help to alleviate this problem does anybody know something about it?
DANIEL HERNANDEZPLATING SHOP - BUCARAMANGA, SANTANDER, COLOMBIA
January 13, 2008
Daniel,
I'm curious HOW you have found citric acid helps with iron contamination. If you use air agitation and the bath ph at 4.0, the iron will oxidize at a much quicker rate than a solution agitated bath, and a ph lower than 4.0. It would seem to me additions of citric acid would lower the ph, thereby making it more difficult to precipitate iron. I'm sure your nickel supplier has a complexing agent for the bath, or can instruct you with a high ph batch treatment and proper filtering.
Process Engineer - Syracuse, New York
January 16, 2008
Second of two simultaneous responses -- January 16, 2008
Daniel.
Short term the citric acid may help. Long term citric acid will.
1) Cause Fungus on the bath.
2) Tie up so much iron that it can interfere with the function of the bath constituents.
Long term its much safer and better in terms of product quality that you consider:
1) Preventing iron contamination by blocking the source of contamination, after identifying the source.
2) Treating the bath periodically with Hydrogen peroxide at a pH of
5.5 - 6 and removing the precipitated sludge via a good filter of by settlement and decantation. Carbon is used in this treatment @ 1 to 3 gms per liter to clean up the oxidised organics the peroxide destroys.
The Peroxide is dosed @ 0.5 to 1.5 mls per liter.
The treatment is done @ 60 centigrade all through 3 to 4 hours that it takes.
A test in the lab prior to treating the bath will establish the dosage more accurately than I have stated.,.
Asif Nurie [deceased]
- New Delhi, India
First of two simultaneous responses -- January 18, 2008
I guess you ask of citrates in the bath rather than citric acid , because citric acid could decrease the pH. Sometimes suppliers recommend citrates or tartrates. In fact it can helps but you should remember that they increase TOC in the nickel bath. In decorative nickel plating I don't recommend. It is easier to prevent or clean the bath acc. to Mr. Asif Nurie's advice.
Best regards
Janusz LABEDZ
- Warsaw, Poland
Second of two simultaneous responses -- January 18, 2008
Estimado Daniel,
citric acid in small quantities will help to complex iron contamination so it will not disturb your nickel deposition. But it won't help to eliminate it in higher concentration. To eliminate iron I fully support the recommendation of Mark. Also check what's the real source of this contamination.
Saludos cordiales,
Dominik
- Mexico City, Mexico
Thanks a lot
I will take Mr Asif advice it look like the source of contamination was the nickel
- Bucaramanga, Santander, Colombia
January 28, 2008
