Sand blasting on aluminum
We do antique finish by doing sand blasting on aluminium. But we face a lot of problems after doing it; a lot of pin holes are visable after the sand blasting. please advice us what pressure & what kind of grit we can use?
sand blasting on aluPlating shop employee - Sharjah (UAE)
January 11, 2008
At our shop we use a 80 grit glass bead. works for what we perform, also our operating pressure in @ 65-95 depending on what we are blasting at the time.
Ryan Cook
Toccoa, Georgia
January 12, 2008
First of two simultaneous responses -- January 14, 2008
If you are looking for an alternative to blasting, look at mass finishing equip. using dry organics and abrasives media. Our product 6A. Blasting presents a lot of problems. If you continue to use blasting you will need a spherical shaped media and I'm not sure you will get the same finish you are looking for.
AF Kenton
Use some SiC under 35 psi and not longer of 5 sec.
Jose Castellanos- Minneapolis, MN, USA
January 14, 2008
