Ideal work surface for electroplating
I am building a bench for an electroforming/electroplating tank to sit on and would appreciate any advice on the most suitable and economical material to cover the top of the bench. I assume stainless steel would be preferable but wondered if polypropylene or similar would be ok. Thank you. Pete
Peter Moulder
Hobbyist - Dover, England
PVC would be ideal. PP is fine chemically, but is flammable. Stainless would be acceptable but not as good.
