Analysis of Zn-Ni plating & trivalent chrome
Q. We are doing alkaline non-cyanide zinc - nickel alloy electroplating to meet one of our specific customer requirements. At present we do analyse by Atomic Absorption Spectrometric
⇦ this on
Amazon [affil links] method. Due to some un avoidable circumstances, we could not continue our bath analysis (Zinc, Nickel in plating bath & Trivalent Chrome in passivation bath).
We also have ED-XRF and UV Visible spectrometer. We like to standardise this for our analysis purpose. Is it possible to analyse as mentioned above quantitatively? If so, request to mention the international standards to carryout our analysis.
Process Development Engineer - Chennai, Tamilnadu, India
A. AA is best for zinc nickel solution analysis. You should consider getting it going again. I do not personally like XRF for solution analysis, but you can analyze your %Ni in the plate if you can get good standards. Your spectrophotometer could work if you spend some time validating your method. You should buy Aubrey Knowles' book Colorimetric Analysis of Metal Finishing & Metal Working Solutions & Effluents ⇦[this on Amazon affil links], which will give you various methods to try out.
Jon Barrows, MSF, EHSSC
Independence, Missouri
Q. JON:
Why you don't like the XRF method?
Could I know your reasons please?
- Minneapolis, Minnesota, USA
January 2, 2008
January 23, 2008
A. Jose-
It's just my opinion here. Every technology has ideal applications as well as applications that are possible, but not ideal. For Zinc/Nickel plating, XRF is ideally suited for determining the %Ni and %Zn in the final plate as well as the plating thickness. XRF can be outfitted to analyse solutions accurately, but it's just not what they are good at. There are too many other options, like AA, that will give a more reliable result for the wet chemistry. If you have an XRF already with all of the necessary upgrades for solution analysis, then by all means use it. Just run standards to make sure that you are getting a good and repeatable result. Be prepared to be disappointed with the accuracy and precision. My opinion is that you need both the XRF and the AA for a reliable Zn-Ni process.
JON,
Thank you so much with your response. I agree totally with you. AAS
⇦ this on
Amazon [affil links] is the best technique. It only need an expert.
February 27, 2008
