ferric chloride resist for copper etching
I'm trying to do some copper plate etching by screen printing a pattern to be preserved in a bath of ferric chloride ⇦ on eBay or Amazon [affil link] . my chemicals doesn't sell the resist solution only producing it on prefabricated boards, can anyone recommend a liquid that would dry on the copper in a screen printing process. hopefully not toxic to the breath and preserve it in the acid bath...and perhaps another chemical bath that would help dissolve said resist after the process is done
Derek Franz
hobbyist - Camarillo, California, USA
I'd start with Lacquer based paints first, as they can be stripped using lacquer thinner ⇦ on eBay or Amazon [affil link] Flammable! . Screen printing does require thick pastes typically to produce the pattern, so lacquers can be purchased very thick. Check your local art supply stores.
I know for a fact that Sharpies (Indelible ink permanent markers) work great to make repairs to patterned traces in ferric chloride ⇦ on eBay or Amazon [affil link] .
Kevin Dowhower
- Lompoc, California, USA
Try a lacquer based on polyvinyl alcohol; it should resist ferric chloride ⇦ on eBay or Amazon [affil link] solution and can be made photosensitive to create a photoresist. The unexposed material is soluble in water and the exposed parts come off in alkaline stripper
finishing.com is possible thanks to our supporting advertisers, including:
maskcoat banner
