Procedure for Hot dip Galvanizing on electro galvanized steel structures
Can you please clarify the procedure for Hot dip galvanizing on Electro galvanized steel structure having slightly rusted in some of the areas.please don't ignore me because I am waiting for your valuable replay to solve my problem seriously I am facing with my client.
Thanks and regards,
QA/QC manager - Dubai, United Arab Emiratees
I believe that the electrogalvanizing is almost irrelevant because it will be almost instantly and completely stripped in hydrochloric acid.
Sir:
Ted is correct. Just take the steel to a hot dip galvanizer and he will put it into acid and the electro zinc will be stripped off and then the product will be rinsed, fluxed, and put into the molten zinc. The hot dip galvanizer may charge more money for the hot dip galvanizing because in the stripping of the electro zinc some zinc will get into his acid.
