Difference between MIL-A-8625E and MIL-A-8625-F
Q. Hello there, I understand there was a change back in 2003 reference to MIL-A 8625 Rev E to Rev F any idea what the change was about?
Denis Turner
M. Engineer - Vista, California, USA
A. MIL-A-8625F was issued in 1993 and amended in 2003. Among the 2003 changes & clarifications: If sealing of Type III anodizing is specified, corrosion testing is also required.
MIL-A-8625D, MIL-A-8625E, MIL-A-8625F and amendments are freely available from ASSIST: http://assist.daps.dla.mil/quicksearch/
Ken Vlach [deceased]
- Goleta, California
Update: Sorry, that address doesn't work or re-direct anymore. The current address is https://quicksearch.dla.mil/qsSearch.aspx
A. May I suggest that you go to the Assist quicksearch webpage, download copies of revisions E and F and do a gap analysis. The copies are free so all it will cost you is your time.
Brian Terry
Ed. note: True, they're 'free'. American shops taxed to give their Chinese & Indian competitors a free leg up on them; and somewhere in the mix is probably a beltway bandit whose political donations are being returned to him 50X over   :-)
Q. Ken,
MIL-A-8625 Rev. F states that sealing can be specified to improve the corrosion resistance of Type III coatings. However, I do not believe it requires additional testing. Can you site the governing paragraph(s)?
Chris Jurey, Past-President IHAA
Luke Engineering & Mfg. Co. Inc.
Wadsworth, Ohio
luke banner
A. If sealed Type III per MIL-A-8625F is specified, corrosion testing is required per amended Table II (monthly qualification tests).
-From MIL-A-8625F, AMENDMENT 1 (15 September 2003)
Amendment to PAGE 9 of MIL-A-8625F:
TABLE II: Add "2/ III" to column 2, row 3, Applicable type I, IB, IC, II, IIB. Add the following footnote below the table "2/ Type III coatings shall be tested for corrosion resistance only when it is specified that the coating is sealed."
thumbs up sign WANTED TO GIVE A HEADS UP THAT AS OF NOV. 23, 2020
MIL-A-8625 HAS BEEN CHANGED TO MIL-PRF-8625.
Philip J. Verzal
- Cicero, Il USA
August 14, 2021
