We received yellow zinc fasteners instead of shiny
I have a application on an steam system and ordered more fasteners to complete the job, the supplier sent me the correct size fastener but they were " yellow zinc" the fastener we are using are standard high strength and have a shiny finish. Will the yellow zinc work?
Bob Casey
construction - Tullahoma, tTnn
Assuming that the strength rating is correct they will be very slightly better as yellow chromated zinc is more corrosion resistant than bright zinc.
