Removing the powdercoat from GMC truck wheels
I have a 2001 GMC truck and the aluminum wheels have powdercoat coming off. Can I remove the powdercoat with out removing the tires? HELP
Bill Van
Truck owner - Danvers, Massachusetts
It sounds like all you need to do is wait a while and the paint will come off for you! :-) I'm sure that the paint is beginning to flake in some areas, put a wire wheel on an electric hand grinder, thats what I do. Don't use a drill because you won't get enough rpm to do the job. Make sure and wear goggles this on eBay or Amazon [affil links] or face shield this on eBay or Amazon [affil links] because the little wires like to shoot off and stick to everything. You won't have to remove the tires this way.
Sheldon Taylor
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
