Material which does not react with ferric chloride
I am designing a sump pump sytem for one of our treatment plants. But I have low pH and ferric chloride
⇦ this on
Amazon [affil links] problem. Could anyone please gove me some idea about the material type which will not react with ferric chloride.
design engineer - Phila, Pennsylvania, USA
Designing ?
Don't try to re-invent the wheel.
Buy a standard chemical pump for this application. There are hundreds on the market. Any metal finishing supplier will advise you
Double diaphragm pumps with "Viton" contact media, Mag drive chemical pumps.
Chemical pumps are a commodity almost.
I wouldn't rig up anything. Buy a pump that will last you years if it is matched to the solution you are pumping.
Ryan Cook
Toccoa, Georgia
January 12, 2008
We do a lot of business in this field, we use Polypropylene material for all ferric applications in both metal finishing and water treatment applications (subject to temperature). A mag drive pump is also best option to keep plant and fingers clean !
Ashley Fenn- Northants, England
January 13, 2008
I've got good results with Halar coatings for this application.
Jordi Pujol- Sant Celoni, SPAIN
February 6, 2008
