Burned rhodium plating solution
I bought a 4 gram concentrate rhodium solution. I mixed it into 2 liter triple AAA distilled water. When I try to plate a jewelry with it the jewelry burns or rather turns into black. need help
Francis Arceojewelry manufacturer - Manila, Philippines
Why don't you ask the people that sold you the stuff? We are human beings Francis, not clairevoyants or magicians. How can we know what exactly did you buy and are doing?
Second of two simultaneous responses -- 2007
Francis,
You say you bought Rh concentrate, which probably contained
4 grams Rh metal in the small jar. If you are plating in a 2 liter beaker you have to add some reagent grade sulfuric acid (50 ml/l) There is probably nothing in the bath to give you throwing power. Some baths work well with a little phosphoric acid, it tends to give a whiter deposit. I would start out with 10 ml/l on the phosphoric. Watch your voltage, because you are only at 2 g/l Rh metal, so keep it on the low side.
Process Engineer - Syracuse, New York
