Plastic ball plating
I am trying to start a small mail order magic shop. One of the items I wish to sell involves a small shiny plastic ball. I am looking for a inexpensive way to chrome plate them. They are about 3" in diameter with a small hole of about 3/4". I will only need about a dozen plated to start with. I will be grateful for any help in getting these plated. Thanks Dale Burden
Dale Burden- Owensboro, Kentucky USA
Unfortunately, this is not an easy one.
Actual nickel-chrome electroplating on plastic, such as is done on automobile grills and bezels can only be done on certain special grades of plastic. Vacuum metallizing (depositing a shiny aluminum film followed by a thin lacquer) sounds more applicable to your needs but I don't know if you'll find a shop to run such a small order through such expensive equipment.
