Hot-dip-Galvanizing vs. Electrogalvanizing
What is the better method for exterior applications of structural steel components, such as plates, pipes, bolts? Thanks
Mahmoud Halaweh
Design Engineer - Tampa, Florida, USA
Hot dipped coatings are usually much much thicker than electrogalvanized coatings and therefore far more protective, Mahmood. But you probably should be specifying the zinc thinkness. Good luck.
