Cleaning lacquer off tin inside copper frying pan
I have a mauviel copper fry pan that I assume is tin lines. I bought it at a reseller and it has a lacquer on the tin. How do I remove it?
Sara Jane Minehart
- Woodbury, MN, USA
Try 70% acetone this on eBay or Amazon [affil links] Warning! highly Flammable! /30% ammonia this on eBay or Amazon [affil links] mixture (bad smelling and combustible!).Any solvent based paint stripper can be used too. Hope it helps and good luck!
