Atomic Absorption Analysis indicates palladium
Hello.
Is it normal or it is possible to have a reading of palladium in AAS analysis
⇦ this on
Amazon [affil links] when the use lamp and method is lead?
Laboratory technician - Philippines
I don't know how such a thing could be.
A lead lamp is not going to emit at the frequencies that palladium absorbs at. So, how could you be getting a reading at all?
As I recall, the wavelengths are not even close together.
Dave Wichern
That's why I'm wondering when it was happen. Is it the AAS machine had a problem? Do you have an idea regarding this matter?
Joy Buenaventura- Philippines
Could be a problem with the AA, but my bet would be on contamination or technique. In particular, check reagents, glassware, tubing, etc.
James Totter, CEF
- Tallahassee, Florida
Hello,just want to know where I can get palladium in the Philippines? thank you
Chris Lo- Malabon City, Philippines
June 8, 2008
