Process know how of mild steel wire galvanising
Dear sir , I want to start A Mild steel wire galvanising plant but I don't know the process
& theory of cold galvanising ,electro-galvanising , hot galvanising and which process is applicable to me. please help.
Thanking you
Prashant
Prashant Gharat
student - Mumbai
I don't think you should start building the plant yet, Prashant. Presumably you have a customer in mind who wants galvanized wire. Can you find out from them whether they want hot dipped, cold galvanized, or zinc electroplated wire? Books on each of these technologies fill whole shelves or aisles of technical libraries so it is obviously difficult to summarize the technologies in a paragraph or two. But, in general, electrogalvanizing is thin but inexpensive and attractive whereas hot dip galvanizing is heavier and more corrosion resistant. Cold galvanizing is essentially zinc-rich paint.
tedmundmooney@gmail.com - Pine Beach, New Jersey
Dear sir, thanx for replying me , sir I want to know about zincplating ?
please reply
thanking you,
Prashant Gharat
student - Mumbai
The Electroplating Engineering Handbook this on eBay, AbeBooks, or Amazon [affil link] is probably the single volume best suited to introducing zinc plating to someone like yourself who is planning to build an electroplating plant, Prashant.
