SPCC specification for steel
What does the term SPCC refer to in steel specifications?
John Christiansen
I procure metal parts for printers. - Vancouver, Washington, USA
from
"Worldwide Guide to Equivalent Irons and Steels"
by Cverna & Conti
or or
Commercial quality, cold rolled carbon steel sheet/coils per JIS G3141, 'COLD-REDUCED CARBON STEEL SHEETS AND STRIPS' (28 pages, in English). Both low carbon & mild steel grades may be available, and a suffix may be added to indicate hardness. Similar to ASTM A1008/A1008M (supersedes A366/A366M).
Ken Vlach [deceased]
- Goleta, California
SPCC is a grade of commercial steel (commercial quality) referenced in the Japanese standard JIS G3141. It is similar to the CS grades in ASTM A1008/A1008M and A 1008M.
Toby Padfield
automotive module supplier - Michigan
Can anyone please advice me on the difference between SPCD-SD and SPCC-SB/SD. At the present moment, I'm using SPCD-SD. Can I switch from SPCD-SD to SPCC-SB or SPCC-SD? There will be tin plating done on the material before going through the stamping process. Both these materials are from the cold rolled steel family.
Thanks in advance.
Joseph Lau
buyer - Singapore
November 27, 2008
November 11, 2010
SPCC SD/SB
S = standard temper grade
D = dull finish
B = Bright finish
Castor Wong
