Protecting copper and brass from corrosion by epoxy resin and varnish in sea water [Saudi Arabia]
Dear Sir
I am a doctora student of corrosion engineering in girs College of eduction in jeddah. I want books or courses in protiction copper and brass from corrosion by epoxy resin and varnish in sea water and soilin HCL,NaOH,NaCl
Thank you & Regards
girs College of eduction - Jeddah, Saudi Arabia
Hi Saidah,
Shell used to, maybe still have, an EPON 828 epoxy resin
which, they said, would bond to and cure under (sea)
water.
Maybe, I dinna ken, all the epoxies are like this ... this you'll have to ascertain.
Hope this helps.
Freeman Newton [deceased]
