Dechroming Aluminum
Nothing seems to work. I have tried the methods I read on this site and many other sites like this one.I am restoring a 1945 H.D. The aluminum motor parts must stripped for proper restoration.
Thank You,
Patrick McCauleyhobbyist - Bear, DE, U.S.A.
Many plating shops would be able to do this for you, Patrick. There will be nickel plating under the chrome, and copper plating under the nickel. I am surprised that these parts are aluminum though; I would have suspected zinc in 1945.
Unforunately, we have found that when a reader says "I've tried everything and nothing works", without saying what they tried, it almost guarantees that no reader will respond because odds are 10:1 that their effort will be dismissed with "I already tried that and, like I said, it didn't work" :-(
I have been doing stripping and replating on all types of old h-d's for over thirty tears. Maybe I can help. regards,Frank
Frank DeGuire- St. Louis, Missouri, USA
