Nickel plating Mic 6 tooling plate
Hi there,
Does any one have experiece with Nickel plating or EN plating of Aluminum Mic 6 tooling plate (aka Jig plate)?
Product designer - Delta BC Canada
First you must use zincate solution and then you can electroplate Nikel on it.
Shapour Abd Sharif Abadi- Tehran, Iran
Just answering your question, "YES." My firm used to electroless nickel plate hundreds of jig plate rotary tables used to index circuit boards on automatic insertion equipment. We still see callouts for this, however, it's not as common today but we can still provide it. Cast jig plate which is the generic callout for Mic 6 and Alca+ are difficult to clean and activate without creating a non-uniform appearance. This is true for plating or anodizing.
Milt Stevenson, Jr.
Syracuse, New York
You can nickel plate mic-6. Go to Alcoa website.
Jim Keller- Detroit, Michigan
