Passivation process in barrel line
In acid zinc plating, the RPM of barrel is 8 RPM ( required for plating ) and since the same barrels are used in precleaning upto passivation, the barrels rotate at the same RPM in all the baths.
As the barrels rotates at the same speed in Passivation bath also, is it the right speed. I am of the view that a slower rotation may help better passivation converison and lesser damage to chromate film. This comes form the fact that lesser problems are seen in offline passivation( if done in bakskets after unloading from plating barrels).
In case barrel rotation speed is ideal what is the speed and how to do only in passivation in the same line?
Sridhar Balasubramanian
plating shop employee - Madurai, Tamilnadu, India
Hi Sridhar,
You can add an elctronic speed control to your barrel's motor.
Even you can program it to turn forward and backwards.
Saludos
Guillermo Castorena
Jobshop - San Luis Potosi, Mexico
Dear Mr Shridhar,
Why not just dunk the barrels in air agitated baths, twice without rotation during passivation?
regards,
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
Insightful answer, KV. Thanks!
