Prepping beryllium nickel for plating
How do you plate beryllium nickel, what would be a good activator and how would you prep this metal
Ryan Smith
Plater - Coon Rapids, MN, USA
Stay out of cyanide. Strike first in an acid solution, either copper sulphate this on eBay or Amazon [affil links] or nickel. Be is insoluble in CN. Once you cover it with copper from an acid solution, then you can do anything.
robert probert
probertbanner
Q. Is it possible to plate over BeNi? What would the process be like? This is the first time I have ever seen a part come in as BeNi. I know BeNi consists of 97.3% Ni , 2.0% Be, 0.6% Ti, and 0.1% Al.
Thank You
Darius Shafiee
Chemical Analyst - Wilsonville, Oregon
February 1, 2012
