Prepping alum for powder coating
We have changed over to powder coating but have a hard time keeping the powder sticking if we do not clean with Laqor thinner. We are pushing to get the thinnner out of the plant. 99% of what we coat is alum. either bent, machined, or cast. is there a fast cheap solution. Or something that can be added to make our transition easier?
thanks,
PROCESS ENGINEER - Sweetwater, Texas
The good news is that solvent cleaning was never the right approach in the first place, so you shouldn't miss it, Martin :-)
Solvent cleaning removes grease and some soils but it does not pretreat aluminum, as should be done. The aluminum should ideally be chromate conversion coated. This process is more easily applied to a large quantity of small parts than a small quantity of large parts, but can be done either way. These days there are hex-chrome free and totally chrome free conversion coating processes.
Martin, you don't give much information to go on. I assume you are not using anything more than lacquer thinner ⇦ this on eBay or Amazon [affil links] Warning! highly flammable! to clean your substrate (aluminum). This is fine if you're using an oil based liquid topcoat (I.E. Xylene ⇦ this on eBay or Amazon [affil links] , toluene, mineral spirits ⇦ this on eBay or Amazon [affil links] , etc.), because the oil based topcoat will adhere to the same base as is a lacquer thinner . Thus, one of the problems is that lacquer thinner is that it is oil based and can leave residuals on your substrate. You would be better off using isopropyl alcohol ⇦ this on eBay or Amazon [affil links] which is oil free. I think really you should use the proper method which would be using either acids or mild alkaline cleaners and a good rinse. Both will give your substrate an acceptable surface profile in which the powder can stick to. Generally speaking, aluminum will not accept a phosphate coating, but usually there is some transfer of the coating and some chemical companies now offer products that will make their product coat onto aluminum.
![]() Bob Utech Benson, Minnesota |
![]() Ed. note: Bob is the author of: "High Performance powder Coating" on eBay or AbeBooks or Amazon [affil links] |
