How do we continuously remove titanium from an etch tank
We wish to process titanium parts through an etch tank. Tank is essentially made up of sodium hydroxide,triethanolamine, diethanolamine, and sodium gluconate.
Problem is the etch tank solution has to remain under 120 ppm dissolved titanium. We are exceeding this limit after processing only 3 parts. Dumping and refilling a new tank every three parts is not practical. Does anyone know who has already solved this problem? continuous filtering?
Shane Smith
Chem Processor - Tulsa, OK, U.S.
First, what does your vendor say? That'd be my first step.
Titanium is going to be present as some kind of anionic complex. If my vendor couldn't help, I'd look at ion exchange resins.
dave wichern
Dave Wichern
Shane,
Glad to see that you've got your question posted here! As we spoke via E-mail, filtration, chemical precipiation or ion exchange are 3 possibilities. I'll keep an eye here to see what the industry community comes up with.
milt stevenson jr.
Milt Stevenson, Jr.
Syracuse, New York
I would query why the spec demands such a low titanium concentration.
I would be very surprised if you get a convincing answer.
Please let us know.
Thank you for all your input. No solutions yet, (no pun intended) in response to previous comments, a.) Vendor can't help. Industry levels are generally 12,000ppm not 120. b.) customer query did not render any explanations as predicted other than this level was needed (engine parts?)
Shane Smith
- Tulsa, OK, US
Still searching for some method to remove dissolved titanium from tank to maintain.
Shane Smith
- Tulsa, OK, U.S.
FIRST,
Optimize your ETCH procedure (T, t, []) in order to dissolve less Ti.
SECOND,
Use a separation method (already mentionned).
Jose Castellanos
- Minneapolis, MN, USA
