Stainless finishing after welding
I work on a shop and we are starting to weld on stainless steel. I need to return its color to stainless steel after electric arc welding has been done. What can I use to return is color? I have been toll, that there is a product that you brush on the welds areas, wait some minutes, and then rinse with water. What is it? Where can I find it?
Thank you for your help.
Carlos Tejada
shop employee - Miami, Florida, USA
Carlos,
I have used a type of product called 'pickling paste' which is a gelled acid product. We bought it from a local weld supply house. Make sure you get a material intended for stainless steel. This product is dangerous to use if you do not follow the safety recommendations and do not use PPE (such as rubber rubber gloves this on eBay or Amazon [affil links] , face shield this on eBay or Amazon [affil links] , etc.). Also, if you use this material on a large area, you may need to be concerned about proper ventilation if you use this material on a large surface area. You might want to consider mechanical methods instead, such a using abrasives or glass beading.
Thomas Kemp
- Erie, Pa. USA
Was anticipating the same problem. Found a product called BlueAway which is supposed to remove bluing from motorcycle pipes and stainless steel. Found it after a internet search at a motor cycle parts place for 17.99/2.5oz. Haven't tried it yet but may buy some.
Alan Heim
welder/fabicator, Greensboro, No. Carolina
A. Hi Carlos,
Pickling Paste can be used and you should be able to find it at a welding supply.
Micheline Forth
Micheline Forth
- Rincon, Georgia USA
There are three basic ways to remove the weld discoloration from the Heat Affected Zone.
A purely chemical removal takes harsh chemicals, typically a pickle paste as was previously mentioned, usually that is nitric-HF based.
Mechanical removal, i.e. grit blasting, grinding, polishing, buffing, etc.
Electrochemical removal, same basic principle aspolishing but applied locally to the weld where it is needed. A wand electrode can be rigged up yourself with your welder as a current source, and commercial units such as SurFox are also available. Let us know if you would like any help with this.
ray kremer
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
