Are there any ways to the hard chromium coating hardness of the HV1000 above?
Hello everyone,
hf zhao
plating shop employee - Changhzou, Jingsu, China
What hardness have you achieved to date, Zhou, and how did you do it?
The ratio is Cro3:250g/L,H2SO4:3g/L,Cr3+:2-4g/L,T:60 deg ,t:2hrs, 60A/dm2, Hardness is HV850,120 micron thickness can be achieved. Where there are problems? How did you?T hank you
J.H.ZHAO
Readers have claimed that 900-1100 is achievable, but that the proprietary etch-free baths like Atotech's HEEF-25 generate the highest hardness. Letter 11955 addresses almost exactly the same question and is a good starting point. Good luck.
In my experience conventional chrome solutions (chromic acid+sulfuric acid)just did not consistently achieve hardnesses in excess of 950HV. Tests with the high efficiency solutions i.e., HEEF 25 & Ankor 1127 gave consistent hardnesses in excess of 1050HV. Both these solutions seem identical in nature.
Colin Christian
- Sydney, Australia
